Actions on Nodes
Apply node related actions on a single node or a selected set of nodes.
  1. To perform an action on a single node, click the elipsis in the last column.
  2. Select an action from the list.
    • Free: Make the node state as free.
    • Offline: Make the node offline.
    • Comment: Add an informational comment.
    • Configure: Set, Unset, Append or Unappend resources.
    • Remove: Remove the node.
  3. To perform these actions on a multiple nodes, select the nodes and choose an action from the Actions menu.
    Figure 1. Actions Menu
