Configure Nodes
The node management page provides a convenient visual interface to apply PBS configuration on nodes. You can set, unset, append and unappend resources for multiple nodes.
  1. Select the nodes from the table, and choose Configure from the Actions menu.
    Note: To configure a single node, click the elipsis in the last column and select Configure
  2. Select an action from the Configure Nodes panel.
    • Set : Sets a resource (nodes, solver, custom resource etc.) for the selected nodes
    • Unset: Removes the resource set to the selected nodes
    • Append: Adds a resource
    • Unappend: Removes the appended resource
    Figure 1. Configure Resources for Nodes
  3. Click Submit.
