Select Nodes
To perform actions on the nodes, you can select them one by one or by filtering and selecting all the nodes.
  1. To select a single node, select the checkbox next to the node's name.
    Figure 1. Select Single Nodes
  2. To select all nodes which are displayed, click Select All nodes.
    Figure 2. Select All Nodes
    Tip: To select a range of nodes, apply a filter and then click Select All nodes.
