View the Cloud Burst Nodes
View the cloud nodes that have been burst for a bursting scenario.
Information that is displayed about cloud burst nodes:
Machine Name
Hostname of the node.
IP Address
IP address assigned to the node.
Instance Type
Cloud provider instance type (machine type, shape or flavor) of cloud node.
OS image used to burst the node.
  1. Login to Control.
  2. Click the Cloud tab.
  3. Click Bursting from the Infrastructure menu located on the left-hand side of the web page.
  4. Select a bursting scenario by clicking its name.
  5. Click Node.
    Nodes that were burst by the PBS cloud bursting hook are displayed at the top while manually burst nodes are displayed below. By default, the manually burst nodes are grouped by instance type.
    Tip: To group the manually burst nodes by tags, click Tag located to the right of Group by.
    Burst Machines
    Figure 1. Burst Machines
