View Information About a Manually Burst Cloud Node
Display information about a manually burst node such as machine name, IP address, tags, associated OS image and price.
  1. Login to Control.
  2. Click the Cloud tab.
  3. Click Bursting from the Infrastructure menu located on the left-hand side of the web page.
  4. Select a bursting scenario by clicking its name.
  5. Click Node.
    Nodes that were burst by the PBS cloud bursting hook are displayed at the top while manually burst nodes are displayed below. By default, the manually burst nodes are grouped by instance type.
    Tip: To group the manually burst nodes by tags, click Tag located to the right of Group by.
    Burst Machines
    Figure 1. Burst Machines
  6. Under Machines - manually burst, choose one of the following options:
    • To display all machines that have been manually burst, click Manage machines.
    • To display a list of machines that have been burst for a particular instance type, click View.
      View Machine Information
      Figure 2. View Machine Information
    Machines are listed in a table. The table can be sorted in ascending and descending order by clicking on the name of the column. Use the search boxes located below the column names to filter a long list of machines.
    Machine Information
    Figure 3. Machine Information
