/PROP/TYPE36 (PREDIT)
Block Format Keyword Describes the predit property set. This is a beam-like spring element for spot welds modelization.
/PROP/TYPE36/prop_ID/unit_ID or /PROP/PREDIT/prop_ID/unit_ID
prop_title
Iutyp
If Iutyp = 1
Skew_ID prop_ID1 prop_ID2
Xk
If Iutyp = 2
mat_ID
Area IXX IYY IZZ Ray
prop_ID Property identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
prop_title Property title
Iutyp Property type flag.
= 1
PREDIT type 1.
= 2
PREDIT type 2.
(Integer)
Skew_ID Skew identifier
(Integer)
prop_ID1 First property identifier
(Integer)
prop_ID2 Second property identifier
(Integer)
Xk Stiffness for interface
(Real)
[ N m ]
mat_ID Material identifier
(Integer)
Area Area
(Real)
[ m 2 ]
IXX Torsion section inertia IXX.
(Real)
[ m 4 ]
IYY Bending section inertia IYY.
(Real)
[ m 4 ]
IZZ Bending section inertia IZZ.
(Real)
[ m 4 ]
Ray Radius.
= 0
User defines the values: area, IXX, IYY, and IZZ.
0
Area and inertia are computed.
(Real)
[ m ]
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
#              MUNIT               LUNIT               TUNIT
                  kg                   m                   s
/PROP/SPR_PRE/11/2
PRETENSIONNER
#                  M                               sensor_ID     Ilock
                 .05                                       1         0
#              Stif0                  F1                  D1                  E1               Stif1
              100000                   0                 .25                   0                   0
#funct_ID1 funct_ID2
         1         0
/SENSOR/TIME/1
pretentionner
#         Tdelay
                 0.1
/FUNCT/1
Loading force function vs displacement after sensor activation
#                  X                   Y
                  -1                   0
                 -.1                  95
                   0                 100
#ENDDATA
  1. The PREDIT type 2 is only used with Predit Material (/MAT/LAW54 (PREDIT)).
  2. A PREDIT type 2 must be reference by a PREDIT type 1: a spring cannot be associated to a PREDIT type 1 only.
  3. A PREDIT property type 1 can reference two PREDIT property type 2.
