/MAT/LAW54 (PREDIT)
Block Format Keyword This law describes the predit material. This material law is only used with /PROP/TYPE36 (PREDIT).
/MAT/LAW54/mat_ID/unit_ID or /MAT/PREDIT/mat_ID/unit_ID
mat_title
ρ i
E ν
  fct_ID A B N Fscaleyld
AY AZ BY BZ CX
Dc RC ε max
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
E Young's modulus
(Real)
[ Pa ]
ν Poisson's ratio
(Real)
fct_ID Hardening parameter function identifier (optional).
= 0
LAW2 is used and coefficients A, B and N are read.
(Integer)
A Hardening parameter yield coefficient A.
(Real)
B Hardening parameter yield coefficient B.
(Real)
N Hardening parameter yield coefficient N.
(Real)
Fscaleyld Yield function scale factor.
Default = 1.0 (Real)
[ Pa ]
AY Y shear coefficient of component yield.
(Real)
AZ Z shear coefficient of component yield.
(Real)
BY Y moment coefficient of component yield.
(Real)
BZ Z moment coefficient of component yield.
(Real)
CX X torsion coefficient of component yield.
(Real)
Dc Critical damage
(Real)
RC Critical failure
(Real)
ε max Damage strain limit
(Real)
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW54/1/1
Steel
#             RHO_I
             7.8E-9
#                 E                   NU
              21000                   .3
#            fct_ID                    A                   B                   N         Fscale_yld
                  0                   30                 150                  .9                  0
#                AY                   AZ                  BY                  BZ                 CX
                 .2                   .2                  .6                  .6                  0
#                DC                   RC             EPS_max
                 .8                    2                  .7
#ENDDATA
/END
  1. Scale factor is only used for fct_ID; otherwise /MAT/LAW36 (PLAS_TAB) is used.
