/PROP/TYPE44 (SPR_CRUS)
Block Format Keyword This is a spring element property, which represents a simple macro model of a crushable frame in compression, tension, torsion and bending.
Originally, this element was developed in cooperation with PSA PEUGEOT CITROËN.
/PROP/TYPE44/prop_ID/unit_ID or /PROP/SPR_CRUS/prop_ID/unit_ID
prop_title
Mass/ L Inertia / L Kinter Skew_ID Icoupling Ifiltr
K11L K44L K55L K66L Idamp
K5bL K6cL
fct_X+i fct_X-i fct_X-r   Fscale_XY
fct_XX+i fct_XX--i fct_XX+r fct_XX--r Fscale_XXY
fct_YY1+i fct_YY1-i fct_YY1+r fct_YY1-r Fscale_YY1Y
fct_ZZ1+i fct_ZZ1-i fct_ZZ1+r fct_ZZ1-r Fscale_ZZ1Y
fct_YY2+i fct_YY2-i fct_YY2+r fct_YY2-r Fscale_YY2Y
fct_ZZ2+i fct_ZZ2-i fct_ZZ2+r fct_ZZ2-r Fscale_ZZ2Y
X_lim_g X_lim XX_lim
YY1_lim ZZ1_lim YY2_lim ZZ2_lim
If Idamp = 1,
fct_D_x Dscale_x F_x
fct_D_y Dscale_y F_y
fct_D_z Dscale_z F_z
fct_D_xx Dscale_xx F_xx
fct_D_yy Dscale_yy F_yy
fct_D_zz Dscale_zz F_zz
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
prop_title Property title.
Mass/ L Frame mass per unit length.
(Real)
[ kgm ]
Inertia / L Frame inertia per unit length.
(Real)
[ kgm ]
Kinter Contact interface stiffness K i n t e r = A E L . 2
A
Frame area
E
Young's modulus
L
Frame length
(Real)
[ N m ]
Skew_ID Skew system identifier.
(Integer)
Icoupling Coupling flag. 3
= 0
Each element is computed independently.
= 1
Coupling of force and moment in any direction.
(Integer)
K11L Tensile / Compression stiffness, multiplied by L.
(Real)
[ N m ]
K44L Torsional stiffness around X axis, multiplied by L.
(Real)
[ Nm 2 ]
K55L Bending Y stiffness around Y axis, multiplied by L.
(Real)
[ Nm 2 ]
K66L Bending Z stiffness around Z axis, multiplied by L.
(Real)
[ Nm 2 ]
K5bL Shear Bending XY stiffness axis, multiplied by L.
(Real)
[ Nm 2 ]
K6cL Shear Bending XZ stiffness axis, multiplied by L.
(Real)
[ Nm 2 ]
fct_X+i Tensile force function versus strain in X direction.
(Integer)
fct_X-i Initial compression force function versus strain in X-direction. Used for elements in the initial state. 4
(Integer)
fct_X-r Residual compression force function versus strain in X direction. Used for elements in the residual state. 4
(Integer)
Fscale_XY Ordinate scale factor for tensile functions.
Default = 1 (Real)
fct_XX+i Initial torsion moment function versus torsion angle in the positive direction. Used for elements in the initial state.
(Integer)
[ N ]
fct_XX-i Initial torsion moment function versus torsion angle in the negative direction. Used for elements in the initial state.
(Integer)
fct_XX+r Residual torsion moment function versus torsion angle in the positive direction. Used for elements in the residual state.
(Integer)
fct_XX-r Residual torsion moment function versus torsion angle in the negative direction. Used for elements in the residual state.
(Integer)
Fscale_XXY Ordinate scale factor for torsion moment functions.
Default = 1 (Real)
[ Nm 2 ]
fct_YY1+i Initial bending Y moment function versus bending angle in the positive direction for node 1. Used for elements in the initial state.
(Integer)
fct_YY1-i Initial bending Y moment function versus bending angle in the negative direction for node 1. Used for elements in the initial state.
(Integer)
fct_YY1+r Residual bending Y moment function versus bending angle in the positive direction for node 1. Used for elements in the residual state.
(Integer)
fct_YY1-r Residual bending Y moment function versus bending angle in the negative direction for node 1. Used for elements in the residual state.
(Integer)
Fscale_YY1Y Ordinate scale factor for bending Y moment functions for node 1.
Default = 1 (Real)
[ Nm ]
fct_ZZ1+i Initial bending Z moment function versus bending angle in the positive direction for node 1. Used for elements in the initial state.
(Integer)
fct_ZZ1-i Initial bending Z moment function versus bending angle in the negative direction for node 1. Used for elements in the initial state.
(Integer)
fct_ZZ1+r Residual bending Z moment function versus bending angle in the positive direction for node 1. Used for elements in the residual state.
(Integer)
fct_ZZ1-r Residual bending Z moment function versus bending angle in the negative direction for node 1. Used for elements in the residual state.
(Integer)
Fscale_ZZ1Y Ordinate scale factor for bending Z moment functions for node 1.
Default = 1 (Real)
[ Nm ]
fct_YY2+i Initial bending Y moment function versus bending angle in the positive direction for node 2. Used for elements in the initial state.
(Integer)
fct_YY2-i Initial bending Y moment function versus bending angle in the negative direction for node 2. Used for elements in the initial state.
(Integer)
fct_YY2+r Residual bending Y moment function versus bending angle in the positive direction for node 2. Used for elements in the residual state.
(Integer)
fct_YY2-r Residual bending Y moment function versus bending angle in the negative direction for node 2. Used for elements in the residual state.
(Integer)
Fscale_YY2Y Ordinate scale factor for bending Y moment functions for node 2.
Default = 1 (Real)
[ Nm ]
fct_ZZ2+i Initial bending Z moment function versus bending angle in the positive direction for node 2. Used for elements in the initial state.
(Integer)
fct_ZZ2-i Initial bending Z moment function versus bending angle in the negative direction for node 2. Used for elements in the initial state.
(Integer)
fct_ZZ2+r Residual bending Z moment function versus bending angle in the positive direction for node 2. Used for elements in the residual state.
(Integer)
fct_ZZ2-r Residual bending Z moment function versus bending angle in the negative direction for node 2. Used for elements in the residual state.
(Integer)
Fscale_ZZ2Y Ordinate scale factor for bending Z moment functions for node 2.
Default = 1 (Real)
[ Nm ]
X_lim_g Global strain limit in X direction to switch the elements and neighboring frame elements from initial into residual state. This indicates the frame element is completely collapsed.
(Real)
X_lim Same as before, but the switch occurs when strains in the X-direction exceed the limit.
(Real)
XX_lim Same as before, but the switch occurs when shear strains in the XX-direction (torsion) exceeds the limit.
(Real)
[ rad ]
YY1_lim Same as before, but the switch occurs when shear strains in the YY-direction on node 1 exceeds the limit. For neighboring element sharing node 1, all DOFs linked to the node will be switched to the residual state.
(Real)
[ rad ]
ZZ1_lim Same as before, but the switch occurs when shear strains in the ZZ-direction on node 1 exceeds the limit. For neighboring element sharing node 1, all DOFs linked to the node will be switched to the residual state.
(Real)
[ rad ]
YY2_lim Same as before, but the switch occurs when shear strains in the YY-direction on node 2 exceeds the limit. For neighboring element sharing node 2, all DOFs linked to the node will be switched to the residual state.
(Real)
[ rad ]
ZZ2_lim Same as before, but the switch occurs when shear strains in the ZZ-direction on node 2 exceeds the limit. For neighboring element sharing node 2, all DOFs linked to the node will be switched to the residual state.
(Real)
[ rad ]
Ifiltr Strain rate filtering flag.
= 0
No strain rate filtering.
= 1
With strain rate filtering.
(Integer)
Idamp Damping flag.
= 0
No damping.
= 1
With damping.
(Integer)
fct_D_x Damping force-elongation rate curve for X - DOF.
fct_D_y Damping force-elongation rate curve for Y - DOF.
fct_D_z Damping force-elongation rate curve for Z - DOF.
fct_D_xx Damping force-elongation rate curve for XX - DOF.
fct_D_yy Damping force-elongation rate curve for YY - DOF.
fct_D_zz Damping force-elongation rate curve for ZZ - DOF.
Dscale_x Linear damping or function damping scale factor for X – DOF.
Default = 1 (See Comment 10)
(Real)
[ kg s ] or [ N ]
Dscale_y Linear damping or function damping scale factor for Y – DOF.
(Real)
[ kg s ] or [ N ]
Dscale_z Linear damping or function damping scale factor for Z – DOF.
(Real)
[ kg s ] or [ N ]
Dscale_xx Linear damping or function damping scale factor for XX – DOF.
(Real)
[ k g m s ] or [ Nm ]
Dscale_yy Linear damping or function damping scale factor for YY – DOF.
(Real)
Dscale_zz Linear damping or function damping scale factor for ZZ – DOF.
(Real)
F_x Abscissa scale factor on Force-elongation rate curve X - DOF.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
F_y Abscissa scale factor on Force-elongation rate curve Y - DOF.
(Real)
F_z Abscissa scale factor on Force-elongation rate curve Z - DOF.
(Real)
F_xx Abscissa scale factor on Force-elongation rate curve XX - DOF.
(Real)
[ 1 s ]
F_yy Abscissa scale factor on Force-elongation rate curve YY - DOF.
(Real)
[ 1 s ]
F_zz Abscissa scale factor on Force-elongation rate curve ZZ - DOF.
(Real)
[ 1 s ]
In this example, besides stiffness there are also functions to describe the tension, compression, torsion, bending Y, and bending Z load case.
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for prop
#              MUNIT               LUNIT               TUNIT
                   g                  mm                  ms
#-  2. GEOMETRICAL SETS:
/PROP/TYPE44/2/2
prop44 example
#             MASS/L           INERTIA/L              Kinter   Skew_Id Icoupling   Ifilter
              .01267                  52                   0         0         0         0
#                K11                 K44                 K55                 K66     Idamp
           341270000           645300000         17692570000         27269000000         0
#                K5b                 K6c
           200000000           300000000
#FUNCT_X+I FUNCT_X-I FUNCT_X-R                     FSCALE_XY
      1000      1001      1002                             0
#FUNCTXX+I FUNCTXX-I FUNCTXX+R FUNCTXX-R          FSCALE_XXY
      1010      1011      1012      1013                   0
#FUNCYY1+I FUNCYY1-I FUNCYY1+R FUNCYY1-R          FSCALEYY1Y
      1020      1021      1022      1023                   0
#FUNCZZ1+I FUNCZZ1-I FUNCZZ1+R FUNCZZ1-R          FSCALEZZ1Y
      1030      1031      1032      1033                   0
#FUNCYY2+I FUNCYY2-I FUNCYY2+R FUNCYY2-R          FSCALEYY2Y
#FUNCZZ2+I FUNCZZ2-I FUNCZZ2+R FUNCZZ2-R          FSCALEZZ2Y
#            X_lim_g               X_lim              XX_lim
               -.709              -.0455                 .34
#            YY1_lim             ZZ1_lim             YY2_lim             ZZ2_lim
                .137               .1396                .138               .1393
#-  3. FUNCTIONS:
/FUNCT/1000
fct_X+i (tension, initial state)
#                  X                   Y
                  -1               10000
                   0               10000
               .0012               44500
                   1               44500
/FUNCT/1001
fct_X-i (compression, initial state)
#                  X                   Y
                 -.9              -71200
               -.865              -45100
               -.777              -27500
               -.708              -14300
              -.0488              -14200
              -.0454              -14700
              -.0299              -21300
              -.0238              -39700
                -.02              -44500
                   0              -38100
                   1              -38100
/FUNCT/1002
fct_X-r (compression, collapsed state)
#                  X                   Y
                 -.9              -71300
               -.865              -45200
               -.777              -27600
               -.708              -14000
                   1              -14000
/FUNCT/1010
fct_XX+i (initial state)
#                  X                   Y
                  -1              464000
                   0              464000
                 .12              486000
                 .16              479000
                 .19              453000
                 .34              193000
                  .8               70000
                 1.6              181000
                 3.3               84000
                   5               84000
/FUNCT/1011
fct_XX-i (initial state)
#                  X                   Y
                  -5              -84000
                -3.3              -84000
                -1.6             -181000
                 -.8              -70000
                -.34             -193000
                -.19             -453000
                -.16             -479000
                -.12             -486000
                   0             -464000
                   1             -464000
/FUNCT/1012
fct_XX+r (collapsed state)
#                  X                   Y
                  -1              193000
                 .34              193000
                  .8               70000
                 1.6              181000
                 3.3               84000
                   5               84000
/FUNCT/1013
fct_XX-r (collapsed state)
#                  X                   Y
                  -5              -84000
                -3.3              -84000
                -1.6             -181000
                 -.8              -70000
                -.34             -193000
                   1             -193000
/FUNCT/1020
fct_YY1+i, fct_YY2+i (initial state)
#                  X                   Y
                  -1              800000
                   0              800000
                .051              895000
                .082              799000
                .135              534000
                 .24              370000
                 .32              315000
                   1              315000
/FUNCT/1021
fct_YY1-i, fct_YY2-i (initial state)
#                  X                   Y
                  -1             -315000
                -.32             -315000
                -.24             -370000
               -.135             -534000
               -.082             -799000
               -.051             -895000
                   0             -800000
                   1             -800000
/FUNCT/1022
fct_YY1+r, fct_YY2+r (collapsed state)
#                  X                   Y
                  -1              150000
                 -.9              150000
                 -.6              178000
                -.45              250000
                 -.3              462000
                 -.2              663000
                -.15              717000
                 -.1              674000
                .135              534000
                 .24              370000
                 .32              315000
                   1              315000
/FUNCT/1023
fct_YY1-r, fct_YY2-r (collapsed state)
#                  X                   Y
                  -1             -315000
                -.32             -315000
                -.24             -370000
               -.135             -534000
                  .1             -674000
                 .15             -717000
                  .2             -663000
                  .3             -462000
                 .45             -250000
                  .6             -178000
                  .9             -150000
                   1             -150000
/FUNCT/1030
fct_ZZ1+i, fct_ZZ2+i (initial state)
#                  X                   Y
                  -1              500000
                   0              500000
               .0255              700000
                .051              700000
               .1395              380000
               .3375              250000
                   1              250000
/FUNCT/1031
fct_ZZ1-i, fct_ZZ2-i (initial state)
#                  X                   Y
                  -1             -250000
              -.3375             -250000
              -.1395             -380000
               -.051             -700000
              -.0255             -700000
                   0             -500000
                   1             -500000
/FUNCT/1032
fct_ZZ1+r, fct_ZZ2+r (collapsed state)
#                  X                   Y
                  -1              110000
                -.45              110000
                -.15              442000
                 -.1              491000
                -.05              478000
               .1395              380000
               .3375              250000
                   1              250000
/FUNCT/1033
fct_ZZ1-r, fct_ZZ2-r (collapsed state)
#                  X                   Y
                  -1             -250000
              -.3375             -250000
              -.1395             -380000
                 .05             -478000
                  .1             -491000
                 .15             -442000
                 .45             -110000
                   1             -110000
#enddata
  1. This property is linked to two node spring elements.
  2. Kinter is used to calculate interface stiffness when the frame element is referred in a contact.
  3. If Icoupling =1, moments generated by forces are accounted in the global moment balance for each frame element (similar to Iequil =1 flag for spring /PROP/TYPE8 (SPR_GENE)).
  4. To reproduce buckling behavior of a chain of the crushable frames, it is assumed that each element can be either in initial state or in residual state (collapsed). Initially all crushable frame elements are in the initial state and corresponding "initial" force strain curves are used. When the strain becomes higher than the limit X_lim_g for a particular element, the element is switched into residual state. Afterwards, only "residual" force strain curves are used for this element for all DOFs. At the same time, information is sent to the attached frame elements (left and right, defined with property TYPE44 only) and all directions on the both nodes of these elements switch to the residual state.
  5. When the value X_lim and/or XX_lim are reached, all DOFs on the both elements nodes switch to the residual state. Neighboring elements also switch to residual state.
  6. When the value YYi_lim and/or ZZi_lim are reached, all DOFs linked to the node of the element, i switch to residual state. Neighboring element, which share the node, also switch to residual state.
  7. The function fct_X+i or fct_XX+i is linked to both nodes of the frame element.
  8. If skew is defined in the property, the Z-direction is:(1)
    Z = X Λ Y s k e w
  9. If no skew frame is assigned in the property set, the Z-direction is:(2)
    Z = X Λ Y g l o b a l
  10. If the damping function is defined, the damping function formula is used instead linear damping.
    Force linear damping:
    F d a m p = D s c a l e i δ ˙ i with ( i = x , y , z , x x , y y , z z - DOF)
    Force function damping:
    F d a m p = H s c a l e i h ( δ ˙ i F i ) with ( i = x , y , z , x x , y y , z z - DOF)
    Where:
    H s c a l e i = D s c a l e i
    δ ˙ i
    Elongation rate.
    h ( δ ˙ i F i )
    Damping Force-elongation rate curve for each DOF.
    F i
    Abscissa scale factor on Force-elongation rate curve for each DOF.
