/PROP/TYPE26 (SPR_TAB)
Block Format Keyword Defines the tabulated spring property.
/PROP/TYPE26/prop_ID/unit_ID or /PROP/SPR_TAB/prop_ID/unit_ID
prop_title
M       sens_ID Isflag Ileng
Nfunc Nfund Lscale Kmax Dmax Alpha
Loading function cards (Nfunc)
fct_ID1 Fscale Strain_rate
Unloading function cards (Nfund)
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
prop_title Property title.
M Mass. 2
(Real)
[ kg ]
sens_ID Sensor identifier.
(Integer)
Isflag Sensor flag. 3
= 0
Spring element activated when sens_ID activates and cannot be deactivated.
= 1
Spring element deactivated when sens_ID activates and cannot be activated.
= 2
Spring elements are activated, or deactivated state matches the sensor state and can switch back and forth. The spring reference length ( l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiBamaaBa aaleaacaaIWaaabeaaaaa@37CD@ ) is based the spring length at the activation time.
(Integer)
Ileng Input per unit length flag. 2
= 0
Spring properties are input as defined.
= 1
Spring properties are a function of the spring length.
(Integer)
Nfunc Numbers of loading curves.
(Integer)
Nfund Numbers of unloading curves.
(Integer)
Lscale Scale factor for abscissa of loading and unloading functions depending on flag Ileng. 6
Default = 1 (Real)
[ m ]
Kmax Maximum stiffness.
(Real)
[ N m ]
Dmax Failure displacement.
(Real)
[ m ]
Alpha Strain rate filtering factor.
Values between 0.0 and 1.0.
Default value = 1.0 (no strain filtering) (Real)
fct_ID1 Function identifier defining f( δ ) or f( ε ) depending on flag Ileng.
(Integer)
Fscale Scale factor for loading and unloading functions.
(Real)
[ N ]
Strain_rate Displacement or strain rate depending on Ileng which corresponds to a loading or unloading function.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
  1. Let δ = L - L 0 be the difference between the current length and the initial length L 0 of the spring element.
  2. If Ileng=1, the spring properties are based on the reference spring length. The input should be entered as:
    M = m l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbGaey ypa0ZaaSaaaeaacaWGTbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3B0F@ K = k * l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbGaey ypa0Jaam4AaiaacQcacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3BA9@
    Each spring will then have the following properties in the model:
    m = M l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGTbGaey ypa0JaamytaiabgwSixlaadYgadaWgaaWcbaGaaGimaaqabaaaaa@3D49@ k = K l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGRbGaey ypa0ZaaSaaaeaacaWGlbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3B0B@
    Where,
    M MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring values entered in the spring property fields
    m MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring’s actual physical mass, stiffness and damping
    l 0
    Initial spring length which is the distance between node N1 and N2 of the spring
    Dmax
    Entered as engineering strain
    Strain_rate
    Entered as engineering strain rate
  3. Spring is activated and/or deactivated by sensor defined in sens_ID and depends on Isflag:
    • If Isflag = 0, the spring element is activated by the sens_ID and cannot be deactivated. The initial length of the spring is based on the spring length at time=0.
    • If Isflag = 1, the spring element is deactivated by the sens_ID and cannot be activated. The initial length of the spring is based on the spring length at time=0.
    • If Isflag = 2, the spring is activated and/or deactivated by sens_ID and can switch activation state multiple times. If sensor is activated, the spring is active; if sensor is deactivated, spring is deactivated. The spring initial length, l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3AAE@ , is the distance between spring nodes at the time of sensor activation.
  4. Force calculations:
    • If Ileng =0, the force is defined as a function of displacement:(1)
      F = f ( δ , δ ˙ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaciOzaiGacIcacqaH0oazcaGGSaGafqiTdqMbaiaacaGGPaaa aa@3E79@
    • If Ileng =1, the force is defined as a function of strain:(2)
      F = f ( ε , ε ˙ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaciOzaiGacIcacqaH1oqzcaGGSaGafqyTduMbaiaacaGGPaaa aa@3E7D@
    Where,
    ε
    Engineering strain.
    L 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIWaaabeaaaaa@37AD@
    Reference length of the element, with L 0 < δ < MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqGHsislca WGmbWaaSbaaSqaaiaaicdaaeqaaOGaeyipaWJaeqiTdqMaeyipaWJa eyOhIukaaa@3E2A@
  5. Spring forces are calculated using loading and unloading functions for different rates.
    • The rate is determined and the maximum loading force as well as the minimum unloading force is determined by interpolation from the input curves.
    • The behavior between the loading and unloading curves is linear, using Kmax value as the spring stiffness.
    • For both loading and unloading, input curves should be defined in order of strictly increasing strain rate values.
    • To describe spring compression behavior, input curves Force(strain) should be strictly positive.
    • In traction, spring behavior is linear with stiffness equal to Kmax.
      spring_force_a
      clip0107
  6. Lscale is used only when the Ileng =0 (abscissa unit is length); otherwise the default value = 1.(3)
    F = F s c a l e f 1 ( L L s c a l e ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbGaeyyXICTa ciOzamaaBaaaleaacaaIXaaabeaakmaabmaabaWaaSaaaeaacaWGmb aabaGaamitaiaadohacaWGJbGaamyyaiaadYgacaWGLbaaaaGaayjk aiaawMcaaaaa@499E@
    Where, f 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaaS baaSqaaiaaigdaaeqaaaaa@3831@ is the function of fct_ID1.
