Dummy Positioning Tool Start Macro
Use this macro to position dummies.
Task Name | Action | |
Configure Process: | Select either Interactive positioning or Automatic positioning. Depending on the selection, the process tree will change. | |
Interactive Positioning | LoadDummy | You are asked for the PAM-CRASH 2G dummy and the positioner file. When the PAM-CRASH 2G dummy is loaded in HyperMesh, the pampostohm tool is automatically started and the dummy is prepared for positioning. System collectors, systems, and assemblies are created and nodes are associated with the systems. |
LoadNoDummyFiles | Imports other parts of the model, which may be required in order to position the dummy correctly. | |
SelectJoints | Opens the Dummy panel and displays a list of joints in the
model, and allows you to select a joint for viewing the load
curves associated with that joint. You can select which curves
(x,y,z) should be shown, the updatePlot utility shows the
current position of the joint on the load curve by drawing a
vertical line. The deletePlot utility deletes the plots created
by this tool. If you exit this task without deleting plots, you
would need to do that in the delete panel afterwards. 注: Only
the plots will be deleted, none of the load curves will be
deleted from the database.
CreateTransformation | Once finished with the positioning of the dummy, you can save this information into a transformation file. | |
CreateDocumentation | Update the model documentation as well as create HTML documentation of the process. You can also select an image to be embedded in the HTML file. A browser can also be selected to display the HTML file. An .h3d file is also embedded into the HTML documentation. | |
ExportFiles | Save the model as an HyperMesh database as well as in PAM-CRASH 2G format. While exporting in PAM-CRASH 2G format, you have the choice of specifying whether you want to delete the additional entities created by the dummy positioning tool. | |
Automatic Positioning: | LoadOnlyDummy | Same as LoadDummy. |
ExecuteTransformation | Select a transformation file, which will be executed automatically to position the dummy. | |
Documentation | Same as CreateDocumentation. | |
ExportDummy | Same as ExportFiles. |
Materials Supported for Dummy Positioning in PAM-CRASH 2G
For the computation of the minimum and maximum angle for the rotation in each direction, the PAM-CRASH 2G materials 220 and 221 are implemented.
Stop Angle Implementation
Normally, the stop angles are given by load curves. The second and last curve points are used to determine the stop angle. If a load curve has less than four entries, the first and the last entries are used. You can find the implementation of the stop angle in the HM_JOINT_INFO function in the function template of the PAM-CRASH 2G Interface. If load curves are not defined for a joint, default values for stop angles ( -270°C to +270°C ) will be displayed in the Dummy Positioning panel.
Update Initial Rotation Angle in the JOINT Card
The initial rotation angles in the JOINT cards are updated automatically.
To update them, use the macro Update Jt Angles on the Tool page.
