M2 Menu
The M2 menu contains options that set the correct element or load type and enter the appropriate HyperMesh panel.
Auxiliaries
- FRICT
- Enters the Components panel, selects the props collector, and sets カードイメージ = to FRICTION.
- RUPMO
- Enters the Components panel, selects the props collector, and sets カードイメージ = to RUPTURE_MODEL.
- SENSO
- Enters the Sensors panel.
- CURVES
- Enters the Edit Curves panel and sets the radio button to modify.
Safety
- SLIPR
- Sets element type mass = to SLIPRING and enters the Mass panel.
- RETRA
- Sets element type mass = to RETRACTR and enters the Mass panel.
- BAGIN
- Enters the Airbag panel and sets the カードイメージ to BAGIN.
- CHAMB
- Enters the Airbag panel and sets the カードイメージ to CHAMBER.
- GASPC
- Enters the Components panel, selects the props collector, and sets カードイメージ = to GASPEC.
Plot Output
- THNOD
- Enters the Output Blocks panel and changes the type to nodes.
- THELE
- Enters the Output Blocks panel and changes the type to elements.
- SENPT
- Sets element type mass = to SENPT and enters the Mass panel.
Nodals
- FRAME
- Enters the Systems panel.
- NODE
- Enters the Nodes panel.
- INVEL
- Sets load type velocity = to INVEL and enters the Velocity panel.
- VEL3D
- Sets load type velocity = to VEL3D and enters the Velocity panel.
- RVE3D
- Sets load type velocity = to REV3D and enters the Velocity panel.
- ACC3D
- Sets load type acceleration = to ACC3D and enters the Acceleration panel.
- RDV3D
- Sets load type velocity = to RDV3D and enters the Velocity panel.
- RDA3D
- Sets load type acceleration = to RDA3D and enters the Acceleration panel.
- RAC3D
- Sets load type acceleration = to RAC3D and enters the Acceleration panel.
- BOUNC
- Sets load type constraint = to BOUNC and enters the Constraints panel.
- DIS3D
- Sets load type constraint = to DIS3D and enters the Constraints panel.
- DIS3DX
- Sets load type constraint = to DIS3DX and enters the Constraints panel.
- DIS3DM
- Sets load type constraint = to DIS3DM and enters the Constraints panel.
- RAN3D
- Sets load type constraint = to RAN3D and enters the Constraints panel.
- RDD3D
- Sets load type constraint = to RDD3D and enters the Constraints panel.
- CONLO
- Sets load type constraint = to CONLO and enters the Constraints panel.
Analysis by Keywords
- LOADCOLS
- Enters the Collector panel, switches the type to loadcols and sets the カードイメージ to INVEL.
