M1 Menu
The M1 menu contains options that set the correct element or load type and enter the appropriate HyperMesh panel.
PART/
- 3D/2D/1D/LINK
- Enters the Components panel, selects the comps collector, and sets the correct カードイメージ.
MATER/
- 3D/2D/1D/LINK
- Enters the Components panel, selects the mats collector, and sets the correct カードイメージ.
- PLY_DATA
- Enters the Components panel, selects the mats collector, and sets the correct dictionary.
Mass Elements
- MASS
- Sets the element type mass = to MASS and enters the Mass panel.
- NSMASS
- Enters the Interfaces panel and sets the カードイメージ to nsmas.
Constraints
- RBODY
- Sets the element type rigid = to RBODY and enters the Rigids panel.
- NODCO
- Sets the element type rigid = to NODCO and enters the Rigids panel.
- RWALL
- Enters the Rigid Walls panel and set the カードイメージ = to RWALL.
- CNTAC
- Enters the Interfaces panel and sets the カードイメージ = to CNTAC.
- TIED
- Enters the Interfaces panel and sets the カードイメージ = to TIED.
Elements
- BAR
- Sets the element type 1dele = to BAR and enters the 1d Elems panel.
- BEAM
- Sets the element type beam = to BEAM and enters the Beams panel.
- KJOINT
- Sets the element type 1dele = to KJOIN and enters the1d Elems panel.
- JOINT
- Sets the element type 1dele = to JOINT and enters the 1d Elems panel.
- SPRING
- Sets the element type spring = to SPRING and enters the Springs panel.
- SHELL
- Sets the element type tria3 = and quad4 = to SHELL.
- MEMBR
- TRIA_C
- Sets the element type tria3 = to TRIA_C.
- SOLID
- Sets the element type tetra4, pyramid5, penta6, and hex8 = to SOLID.
- BSHELL
- Sets the element type hex8 = to BSHEL.
Link Elements
- PLINK
- Sets the element type mass = to PLINK and enters the Mass panel.
- ELINK
- Sets the element type 1dele = to ELINK and enters the 1d Elems panel.
- LLINK
- Sets the element type 1dele = to LLINK and enters the 1d Elems panel.
- SLINK
- Sets the element type tria3 = and quad4 = to SLINK.
