接触ペアの隙間定義の作成
接触ペアの新しい隙間定義の作成手順は、選択した隙間のタイプによって異なります。
VALUE
- In the Type field, select VALUE.
In the Value field, specify an initial clearance/overclosure for the entire set
of secondary nodes.
注: A positive values specifies an initial clearance, and a negative value specifies an initial overclosure.
- Click 適用.
TABULAR WITH INPUT FILE
- In the Type field, select TABULAR WITH INPUT FILE.
In the Input File field, specify an input file that contains the clearance
data.
注: The input file can be a file name, relative path, or complete file path. A maximum of eighty characters are allowed in this field.
- Click 適用.
TABULAR WITH BOLT
When using the TABULAR WITH BOLT clearance type, you can define clearance using nodes, node sets, or both nodes and node sets. In the example below, clearance is being defined using both nodes and node sets.
- In the Type field, select TABULAR WITH BOLT.
Specify the following:
- Half Thread Angle
- Pitch
- Major Thread Diameter
- Minor Thread Diameter
図 1. - To define clearance with a node, select the node checkbox.
- To add a data line to the table, click Add.
In the first data line, double-click the Node Id
field.
図 2. - Using the node collector, select a node.
- To apply your selection and go back to the Contact Manager, click proceed.
- Clearance Value
- a(X)
- a(Y)
- a(Z)
- b(X)
- b(Y)
- b(Z)
図 3. - To define clearance with a node set, select the Node set checkbox.
- オプション: To create a new node set or edit an existing node set using the Entity Sets panel, click Create/Edit.
In the first data line, click the Node Set field and
then select a node set from the list.
図 4. -
- Clearance Value
- a(X)
- a(Y)
- a(Z)
- b(X)
- b(Y)
- b(Z)
- Click 適用.
TABULAR WITH BOLT AND INPUT
When using the TABULAR WITH BOLT AND INPUT clearance type, you can define clearance using nodes, node sets, or both nodes and node sets. In the example below, clearance is being defined using both nodes and node sets.
- In the Type field, select TABULAR WITH BOLT AND INPUT.
field.
図 5. - Using the node collector, select a node.
- Clearance Value
- 1st Normal
- 2nd Normal
- 3rd Normal
- In the first data line, click the Node Set field and then select a node set from the list.
- Clearance Value
- 1st Normal
- 2nd Normal
- 3rd Normal
- Click 適用.
