trim
This command allows the user to trim a surface using a curve or set of curves.
Inline mode usage
- trim -h
- Displays the help file that summarizes the parameters for this command.
- trim –s <surface> -c <curve>
- Trims the selected surface <surface> with the selected curves <curve>.
Interactive mode usage
- Invocation
- trim
- Parameters
- Surface to trim.
- Cutting closed curves to be used for the trim operation.
We want to create a circular hole (with radius 1) in the center of a plane. This plane is defined as follows:
>plane
Select first point [x y z]: 0 0 0
Select second point [x y]: 4 4
> explode
Select objects on screen (Press enter when done) // Select the plane and press Enter.
We need to explode the plane so it will be treated as a surface and not as an object. Next, we will define our cutting curve, in this case, a circle. This is done with the following command:
>circle
Center [x y z]: 2 2 0
Radius [double]: 1
Figure 1. Plane and cutting circle
We have the surface to trim and the cutting curve, so we can proceed with the trim
operation. However, the direction of the curve is going counter-clockwise (we can
check this by selecting the curve and showing the normals with the button on the toolbar), so the trim
operation will delete the part of the plane that is outside the circle1.
We want exactly the opposite, so will need to invert the normals of the circle. This
can be done simply clicking on the geometry view while the normals of the curve are
being shown.
Now we can finally perform the trim operation. This is done in the following way:
> trim
Select one NURBS surface to trim (Press enter when done): // Select the plane
Select cutting closed curve(s) (Press enter when done): // Select the circle
Figure 2. Trimmed plane
