ellipse
This command draws an ellipse.
Inline mode usage
- ellipse -h
- Displays the help file that summarizes the parameters for this command.
- ellipse –n <name> -p <center_x> <center_y> <center_z> <radius_x> <radius_y>
- Draws an ellipse centered at the specified point and with the defined radii.
Interactive mode usage
- Invocation
- ellipse
- Parameters
- Center point of the ellipse.
- Radius along the X axis.
- Radius along the Y axis.
Example:
>ellipse
Center [x y z]: 0 0 0
First radius (double): 1
Second radius (double): 5
Result:
Figure 1. Resulting ellipse
