rebuildSurface
This option allows rebuilding any given surface by sampling and interpolating the resulting points.
Inline mode usage:
- rebuildSurface -h
- Displays the help file that summarizes the parameters for this command.
- rebuildSurface –s <surface> -p <uDegree> <uPoints> <vDegree> <vPoints>
- Rebuild the selected surface
- rebuildSurface –c –s <surface> -p <uDegree> <uPoints> <vDegree> <vPoints>
- Rebuild the selected surface, keeping the original surface.
- rebuildSurface -noTrim –s<surface> -p <uDegree> <uPoints> <vDegree> <vPoints>
- Rebuild the selected surface not trimmed.
- rebuildSurface –c -noTrim –s <surface> -p <uDegree> <uPoints> <vDegree> <vPoints>
- Rebuild the selected surface not trimmed, keeping the original surface.
Interactive mode usage:
- Invocation
- rebuildSurface
- Parameters
- Selected surface.
- Degree along the U-dimension.
- Degree along the V-dimension.
- Points along the U-dimension.
- Points along the V-dimension.
Example:
For this example, one surface must be defined.>rebuildSurface
U-Degree [integer](default=2): 1
V-Degree [integer](default=2): 1
Points in u direction [integer](default=3): 2
Points in v direction [integer](default=3): 2
Original surface:
Figure 1. Original surface used for the rebuildSurface operation
Resulting surface:
Figure 2. Resulting surface after the rebuildSurface operation
