connectCurves
Connects the selected curves.
Inline mode usage
connectCurves -s all|name... -n resul_name
Interactive mode usage:
- Invocation
- connectCurves
- Usage
- Step 1: Select curves on screen (Press enter when done)
The newFASANT User Guide contains examples with step-by-step instructions on how to get started with newFASANT.
The newFASANT User Guide contains a collection of examples that teaches you newFASANT concepts and essentials.
The newFASANT utilities allows you to set up a remote server, use the batch utility to mesh and execute a project or upload a project to a queueing system.
An overview of the newFASANT graphical user interface is given.
Results can be post-processed to obtain customized results.
A large collection of antennas are supported as well as importing radiation patterns and specifying the antenna feeding.
Materials can be defined, edited, deleted and assigned to specific surfaces or objects.
The command line can be used to draw geometries or change the GUI configuration.
The next table represents an exhaustive list of the commands supported in newFASANT. These commands are ordered by the function they perform.
This option is useful to identify the curves and surfaces in the geometry that describe large curvatures. Given a desired angle as reference (in degrees), if some of the selected objects describe curvatures bigger than the reference angle the points are generated where the curves has varied their direction every angular step. The detected points may be only visualized or also added to the geometry.
This tool allows the user to detect the edges in the geometry. The edges may be only visualized or also added to the geometry.
This tool allows the user to detect the naked borders (borders of the surfaces that are not in contact with other ones) in the geometry. The borders may be only visualized or also added to the geometry.
This tool allows the user to calculate the angle (in degrees) between two given vectors. Vectors are specified by an initial point and an end point.
This command allows the user to draw a circumference arc specifying its central point, radius, initial and final angles (in degrees), in this order.
This command returns the total area of the selected surfaces.
Copies an object or a set of objects a given number of times in the direction of each of the axes. This option lets the user easily create a matrix of geometries.
Creates an array of planar elements along surface.
This option toggles the visualization of the three axes in the view area and allows to modify their length.
Add new "Bent dipoles" structure to the geometry.
This command computes the resulting surfaces of subtracting the second object to the first one (A minus B operation), that is, the regions of the first object that are not contained in the second object.
This command select the surfaces of the first object that are contained in the second one (A inside B operation).
This command creates an object with the regions of the two selected objects that are included in both of them (A AND B operation). Note that the original objects used for the operation will be deleted.
This command select the surfaces of the first object that are not contained in the second one (A outside B operation).
This command introduces the cuts that an object produces in another one.
This command creates a new object that encloses the regions of the two selected objects that are included in any of them (A OR B operation). Note that this command will delete the original objects.
This command selects the surfaces of the two selected objects that are included only in one of them (A XOR B operation).
This command draws a box at the specified coordinates taking a square bounded by width, depth and height.
Add a new capacitance to the geometry.
This command draws a circle with a specified radius and center point.
Add a new plane with a circular hole in it to the geometry.
This command draws a closed or open cone.
Generates a new surface to join the two selected ones (if they are not in contact).
Creates a coons patch through a selected loop of 2, 3 or 4 curves.
Copies an object or set of objects. The difference between this command and the array command is that the copy command copies objects by applying a displacement vector with an arbitrary direction.
This command draws a cross-shaped surface.
Add a new plane with a cross shaped hole in it.
This command creates a NURBS (Non-Uniform Rational B-Spline) curve by specifying its control points (as well as the weight of each one). Note that the number of points must be at least one more than the degree of the curve.
This command draws a curve with three functions that define points in Cartesian coordinates.
This option allows the user to draw a curve that goes through a set of points by applying polynomial interpolation.
Creates a closed or open (i.e. without taps) cylinder.
This command deletes an object or set of objects from the geometry. It is also possible to delete all the command history.
This command creates a disk by specifying its center point and the radius.
This option allows the user to calculate the Euclidean distance between two given points.
Creates a copy of an existing object at the same position as the original one.
This command draws an ellipse.
This command draws an ellipsoid in the geometry.
This command closes the application.
Divides an object into a specific number of surfaces.
This command lets the user export the geometry contained in the current project into a file (NURBS, IGES, DXF, MSH, NAS…)
This option allows the user to trim a surface with a loop and extrude the resulting cut off part of the surface.
This command creates a surface by sweeping a curve along a translation vector, or by joining all of its points to a central point.
Creates a closed object by sweeping the chosen surfaces in the direction of their normal vectors. This command is a simplified version of the extrudeSurface command as the extrusion direction is set to the normal vector of the surfaces.
This option allows the user to create a solid volume from a surface. The original surface is not removed from the view area after the extrusion has been performed.
This command creates a trapezoidal prism.
This command groups the selected surfaces into an object.
This command displays the help file that summarizes the parameters for the console or the selected command.
Adds a new hexagon to the geometry.
This command creates a hyperbolic curve on the geometry.
This command draws a hyperboloid on the geometry.
Creates a stripline interdigital filter.
This command inverts the direction of the normal vectors of a curve, surface or solid object.
This command returns the total length of the selected curves.
This command generates a straight line in the geometry.
This command allows the user to transform the selected objects, which are assumed to be positioned in the default Cartesian coordinate system, to the current coordinate system (determined by the reference plane).
This command creates a mesh from a set of surfaces.
This command converts a mesh to a set of (open) surfaces.
This command moves an object by applying a translation vector to it.
This command create a tangent ogive in the geometry.
Add a new open ring to the geometry.
This command draws a parabola.
This command creates a paraboloid in the geometry.
This command generates a straight line in the geometry perpendicular to the selected object that cross the introduced point.
This command create a circular cross-section tube that surrounds the selected curve with the specified radius.
This option allows the generation of planar surfaces from multiple coplanar lines.
This command creates a plane in the geometry.
This command defines a point in the geometry.
This command allows the user to create several points on the geometry.
The user can draw several points along a selected curve. The points are generated along a curve as a result of its division in several subcurves (the curve is not split) of identical size.
The user can draw several points along a selected curve. The points are generated along a curve when the desired length of a subcurve (the input curve is not split) is reached.
The user can draw several points along the two parametric dimensions of a selected surface.
This command draws a polygon in the geometry.
This command projects points and curves onto surfaces or objects. The original points and curves are not modified.
This option allows rebuilding any given curve by sampling and interpolating the resulting points.
This option allows rebuilding any given surface by sampling and interpolating the resulting points.
This command draws a rectangle in the geometry.
Adds new hole rectangle in geometry.
This command renames an object to a given new name
This command creates a surface by revolving a curve around a rotational axis.
This command draws a rhomboid in the geometry.
Adds new ring in geometry panel.
This command rotates an object a given number of degrees around a specified axis.
This command scales the size of an object or objects by a factor specified by the user.
This command scales only the specified dimension (X, Y, Z) of an object or objects by the factor specified by the user.
This command scales only the two specified dimensions (X, Y, Z) of an object or objects by the same factor specified by the user.
This command scales the three dimensions (X, Y, Z) of an object or objects by the same factor specified by the user.
This command scales the three dimensions (X, Y, Z) of an object or objects by the three different scale factors for each dimension specified by the user.
This command loads and executes a script or saves the history to script.
This command draws a straight segment in the geometry.
This command draws a semicircle in the geometry.
This command allows visualizing and/or changing the value of a parameter.
This command creates a surface by interpolating it through several curves.
This command creates a new sphere in the geometry.
Create a spiral curve with a given center, radius and number of turns.
Adds a new spiral cross to the geometry.
This command projects curves onto surfaces or objects and split them with the resulting projections. The projected curves are only used to split the target surfaces and they are not included to the geometry.
Split operation applied to curves.
Add a new split ring to geometry.
This option is useful when a surface needs to be split at a given isoparametric curve. This operation may be used to separate surfaces with extreme curvatures in different parts.
This option is useful when a surface needs to be split at a given grid of isoparametric curves. This operation may be used to separate surfaces with extreme curvatures in different parts.
Split operation on surfaces.
Adds new strip cross in geometry.
Adds new strip hexagon in geometry.
Add a new hollow trifilar surface to the geometry.
This command allows the user to create a NURBS (Non-Uniform Rational Basis Spline) surface specifying its control points.
This command allows drawing a surface that is bound by the corner points specified by the user.
This command creates the curves that delimit a surface.
Adds a new ellipse to the geometry.
This option creates a surface by defining two parameters and three functions.
This command allows drawing a surface that goes through a set of points specified by the user.
Any isoparametric curve of a surface (in the U- or V-dimension) may be obtained by using this command.
Create a spiral surface with a given width, radius and number of turns.
Interpolate a surface through the curves chosen by the user.
This command creates an object that is symmetric to the original one with respect to a plane of symmetry.
This command generates a straight line in the geometry tangent to the selected curve that cross the introduced point.
Adds a new T cross (a cross with T-shaped ends) to the geometry.
Add three dipoles to geometry.
Add three joined dipoles to geometry.
Adds a new torus to the geometry panel, receiving the central point, the minor (inner) radius and the major (outer) radius of the torus.
Add a new trifilar to the geometry.
This command allows the user to trim a surface using a curve or set of curves.
Deletes already existing parameters.
This command removes cutting loops of the selected surfaces.
GTD can be used for 3D analysis of on board antennas and coverage parameters for radiocommunications systems.
PO is used for radar cross section analysis of electrically large and complex targets using physical optics (PO).
GTD-PO combines the GTD and PO high-frequency techniques for the RCS analysis of complex bodies as well as antenna and radio propagation in large urban environments.
MONCROS is used for 3D radar cross section (RCS) using the method of moments (MOM) technique.
MOM is used for the 3D analysis of complex antennas, on board antennas, electromagnetic compatibility and radar cross section (RCS).
Periodical structures is used for the analysis and design of reflection and transmission coefficients in periodical structures and metamaterials.
PE is used for the analysis of radio-wave propagation over land and sea for medium and large distances.
Ultrasound is used for the 3D analysis of ultrasound emitting sources and time delay response simulation.
View the list of commonly used acronyms in newFASANT.
