splitCurves
Split operation applied to curves.
Inline mode usage
splitCurves -h
Displays the help file that summarizes the parameters for this command.
splitCurves–s <curve1><curve2>
Splits between selected curves.
splitCurves–c <object1> –s <curve1>
Selected curves are split by the cutting objects.
splitCurves–p <parametric_value><curve1>
Selected curve is split on parametric space.
Interactive mode usage
Invocation
splitCurves
  • Selected curves.
  • Cutting objects (with –c option).
  • Parametric value (with –p option).
Two curves are necessary for this example.
      splitCurves
Select the curves to be split on screen (Press enter when done):
Result:
Figure 1. Resulting split curves
