invertNormals
This command inverts the direction of the normal vectors of a curve, surface or solid object.
Inline mode usage:
- invertNormals -h
- Displays the help file that summarizes the parameters for this command.
- invertNormals -all
- Invert the normal vector of all objects.
- invertNormals
- Invert normals by selecting objects on screen.
- Invocation
- invertNormals
- Parameters
- The curve, surface or object whose normal surface vectors are to be inverted.
Figure 1. Visualizing normals
We’re going to invert the normal vectors of an existing surface. To help us visualize this, select the surface and select the View Normals option by clicking the button. The normal vectors are now visible on the geometry view:
>invertNormals
Select objects on screen (Press enter when done): // Select the surface and press Enter
>Figure 2. Result of inverting the normals
