splitSurfaceByIsoparam
This option is useful when a surface needs to be split at a given isoparametric curve. This operation may be used to separate surfaces with extreme curvatures in different parts.
Inline mode usage
- splitSurfaceByIsoparam -h
- Displays the help file that summarizes the parameters for this command.
- splitSurfaceByIsoparam–s <surface> -p <parametric_value>
- Splits a selected surface by an isoparametric line in the u-dimension
- splitSurfaceByIsoparam–u –s <surface> -p <parametric_value>
- splitSurfaceByIsoparam–v –s <surface> -p <parametric_value>
- Splits a selected surface by an isoparametric line in the v-dimension
Interactive mode usage
- Invocation
- Parameters
- Selected surface.
- Parametric value.
A curve surface are necessary for this example.
Select one surface to be split on screen (Press enter when done):
Tip v to change the dimension or insert the parametric value of u(0,1): 0.25
Result:
Figure 1. Split surface on u-dimension
