distance
This option allows the user to calculate the Euclidean distance between two given points.
Inline mode usage:
distance -h
Displays the help file that summarizes the parameters for this command.
distance <point1> <point2>
Calculates and displays the distance between the two specified points. Each point is represented by its three components, separated by a blank space.
Interactive mode usage:
Invocation
distance
  • First point
  • Second point
Example:
> distance
Select first point [x y z] 3 0 0
Select second point [x y z] 0 4 0
The distance between points is 5.0
