exit
This command closes the application.
Inline mode usage
- exit -h
- Displays the help file that summarizes the parameters for this command.
- exit
- Closes the application.
When this command is issued, a dialog will require a confirmation from the user to exit newFASANT. If a project is already opened, it will give the possibility to save the project before exiting.
Figure 1. Dialog asking to save changes to the current project
