surfaceFromEdges
Inline mode usage
- surfaceFromEdges -h
- Displays the help file that summarizes the parameters for this command.
- surfaceFromEdges –s all
- Selects all curves of the scene.
- surfaceFromEdges –s <name>
- Selects <name> curve.
Interactive mode usage
- Invocation
- surfaceFromEdges
- Parameters
- Two, three or four curves used for the creation of the coons patch. The set of selected curves must form a closed loop.
command> arc
Center [x y z]: 0 0 0
Radius [double]: 1
Initial angle [degrees]: 0
Final angle [degrees]: 90
command> arc
Radius [double]: 1
Initial angle [degrees]: 90
Final angle [degrees]: 180
command> arc
Radius [double]: 1
Initial angle [degrees]: 180
Final angle [degrees]: 270
command> arc
Radius [double]: 1
Initial angle [degrees]: 270
Final angle [degrees]: 360
command> surfaceFromEdges
Select a closed set of 2, 3 or 4 curves (press Enter when done):
command>
Result
Figure 1. Disk generated from 4 edge arcs
