circle
This command draws a circle with a specified radius and center point.
Inline mode usage
- circle -h
- Displays the help file that summarizes the parameters for this command.
- circle –n <name> -p <x_center> <y_center> <z_center> <radius>
- Draws a circle named <name>with center coordinates (<x_center>, <y_center>, <z_center>) and specified radius <radius>.
Interactive mode usage:
- Invocation
- circle
- Parameters
- Center point, in "x y z" format: x y z.
- Radius of the circle: radius.
Example:
>circle
Center [x y z] 0 1 0
Radius [double] 3
Result
Figure 1. Resulting circle
