capacitance
Add a new capacitance to the geometry.
Inline mode usage:
- capacitance -h: Display a help message.
- capacitance -n name -p centerX centerY centerZ separation width height length: Create a new capacitance.
Screen usage:
The following steps will be needed in order to create a new capacitance:
- Select center [x y z]: Central point of the capacitance (equidistant to both plates).
- Separation between plates [separation]: Separation between the two plates.
- Size of plate [width height]: Size of both plates.
- Length [length]: Length of the outer segment.
Remark: All input values (besides the central point components) must be greater than zero.
Figure 1. capacitance example
