PARAM, SRCOMPS
Bulk Data Entry Outputs the strength ratios for composite elements that have failure indices requested.
Parameter Values Description
SRCOMPS <YES, NO, blank>
YES
The strength ratios are output for composite elements that have failure indices requested. (The Output formats currently supported are: H3D, HM, OP2, PCH and OPT).
NO (Default), blank
The strength ratio will not be output.
  1. The Strength Ratios that are output as a result of PARAM, SRCOMPS, YES depend on the Failure Theory specified by the user. The following equations show the relationship between the Failure Index and the Strength Ratio for different Failure Theories.
    Hill Failure Theory:
    Strength Ratio = 1 Failure Index
    Hoffman Failure Theory: There is no direct relationship between the Strength Ratio and Failure Index (refer to Composite Laminates in the User Guide for more information). OptiStruct solves the quadratic equation to find the strength ratio.
    Tsai-Wu Failure Theory: There is no direct relationship between the Strength Ratio and Failure Index. (refer to Composite Laminates in the User Guide for more information). OptiStruct solves the quadratic equation to find the strength ratio.
    Maximum Stress (Strain) Failure Theory:
    S t r e n g t h   R a t i o = 1 F a i l u r e   I n d e x MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiaadofacaWG0b GaamOCaiaadwgacaWGUbGaam4zaiaadshacaWGObGaaeiiaiaadkfa caWGHbGaamiDaiaadMgacaWGVbGaeyypa0ZaaSaaaeaacaaIXaaaba GaamOraiaadggacaWGPbGaamiBaiaadwhacaWGYbGaamyzaiaabcca caWGjbGaamOBaiaadsgacaWGLbGaamiEaaaaaaa@500E@
    Transverse Shear Failure Theory:
