TABLEMD
Bulk Data Entry Defines a multi-dimensional tabular function which identifies single or multiple X-values for a single Y-value.
TABLEMD | TID | NDEP | |||||||
Y1 | X1_1 | X1_2 | X1_3 | etc | etc | etc | X1_7 | ||
X1_8 | etc | X1_10 | |||||||
Y2 | X2_1 | X2_2 | X2_3 | etc | etc | etc | X2_7 | ||
X2_8 | etc | X2_10 |
TABLEMD | 32 | 6 | |||||||
-3.0 | 6.9 | 2.0 | 5.6 | 3.0 | 5.6 |
TID | Table identification
number. No default (Integer > 0) |
NDEP | Identifies the number of
dependencies. No default (Integer > 0 and ≤ 10) |
Yi | Yi
values. No default (Real or ENDT) |
Xi_i | Xi
values for each corresponding Yi value. No default (Real or ENDT) |
- At least one continuation entry must be specified.
- When TABLEMD is used in OSTTS damage calculations, NDEP=1 should be specified. The Xi_j values should be specified in ascending order only.
