MBREQE
Bulk Data Entry Defines a multibody solver output request to output the results of a set of expressions.
| MBREQE | RSID | RID | E1 | E2 | E3 | E4 | E5 | E6 |
| MBREQE | 235 | 10 | 20 | 30 | 40 |
| RSID | Request set identification
number. (Integer > 0) |
| RID | Request identification
number. Request ID must be unique with respect to all other MBREQM and MBREQE cards. (Integer > 0) |
| E1 | ID of
MBVAR. (Integer > 0) |
| E2, … E6 | Additional
MBVAR IDs. Default = blank (blank or Integer > 0) |
- The request evaluates the expression at every output step.
- The values are always set to 0, if the expression is not specified.
- Request set will be specified in the subcase definition.
