LOADJG
Bulk Data Entry Defines loading for joint connector JOINTG Bulk Data Entry.
| LOADJG | ID | TID | |||||||
| JID1 | DOF | VALUE | |||||||
| JID2 | DOF | VALUE | |||||||
| etc |
| LOADJG | 3 | 3 | |||||||
| 2 | 1 | 1.0 | |||||||
| 3 | 4 | 2.0 |
| ID | Load set identification
number. (Integer > 0) |
| TID | Identification number of a
TABLEDi entry that defines loading scale factors versus time.
The loads on the VALUE fields are multiplied with the scale
factors to determine time-dependent loads on the joint degrees of freedom. Default = blank (Integer > 0) |
| JIDi | Identification number of a JOINTG Bulk Data Entry on which the loading is to be applied. | |
| DOF | Degree of freedom component number. No default (Integer 1 through 6) |
| VALUE | Load value to be applied on the
identified degree of freedom for the specified JOINTG joint. No default (Integer > 0) |
- The types and directions of motion for the
component numbers are:
Component Number(s) Motion Type Motion Direction(s) 1, 2, and 3 Displacement X,Y,Z 4, 5, and 6 Rotation X,Y,Z
