MATF
Bulk Data Entry Defines material properties and failure model parameters for Failure criteria calculations.
MATF | MID | ||||||||
CRI | CRITERIA | TID/V1 | V2 | V3 | V4 | V5 | V6 | ||
V7 | V8 | V9 | V10 | V11 | V12 | W1 | |||
W2 | W3 | W4 | |||||||
etc |
MATF | 100 | ||||||||
CRI | PUCK | 3.E5 | 3.E5 | 3.E5 | 3.E5 | 3.E5 | |||
0.25 | |||||||||
0.25 | 0.25 |
MID | Material identification
number. (Integer > 0) |
CRI | CRI flag indicating that the failure criterion input data are to follow. 9 | |
CRITERIA | Character String
representing the chosen failure criterion.
No default |
TID | Identification number of a TABLEMD entry that identifies the equivalent plastic strain (Yi) at the onset of damage versus temperature (Xi). 7 | |
Vi | Material stress limits.
2
3 (Real > 0.0) |
Wi | Parameters for failure
criteria calculations. 4
(Real > 0.0) |
- MID field may refer to MAT1, MAT2, MAT8, MAT9 or MAT9OR entries.
- For laminated shells
(PCOMP/PCOMPP/PCOMPG).V1, V2, through V5 specify material stress/strain limits.
- V1
- Tensile stress/strain limit in longitudinal direction
- V2
- Compressive stress/strain limit in longitudinal direction
- V3
- Tensile stress/strain limit in lateral direction
- V4
- Compressive stress/strain limit in lateral direction
- V5
- In-plane shear stress/strain limit
For STRS failure criterion, the input allowables should be stress-allowables.
For STRN failure criterion, the input allowables should be strain-allowables. OptiStruct will not conduct internal conversion for STRN failure criterion. The values defined are directly used as strain-allowables for STRN failure criterion on MATF.
For STRN failure criterion, the STRN field on MAT8 entry has no effect on the allowable values defined on the MATF entry.
For Solid Elements (MAT9/MAT9OR) and Continuum Shells (PCOMPLS).
V1, V2 through V9 specify material stress/strain limits.- V1
- Tensile stress/strain limit in 1-1 direction
- V2
- Compressive stress/strain limit in 1-1 direction
- V3
- Tensile stress/strain limit in 2-2 direction
- V4
- Compressive stress/strain limit in 2-2 direction
- V5
- Tensile stress/strain limit in 3-3 direction
- V6
- Compressive stress/strain limit in 3-3 direction
- V7
- Shear stress/strain limit in 1-2 direction
- V8
- Shear stress/strain limit in 2-3 direction
- V9
- Shear stress/strain limit in 1-3 direction
Coordinate system 1-2-3 are user-defined for continuum shell elements or solid elements with MAT9.
For STRS3D failure criterion, the input allowables should be stress-allowables.
For STRN3D failure criterion, the input allowables should be strain-allowables. OptiStruct will not conduct internal conversion for STRN3D failure criterion. The values defined are directly used as strain-allowables for STRN3D failure criterion on MATF.
- V10,
V11, and V12 are used for
TSAI/TSAI3D criterion.
- For TSAI:
- V10: the coupling coefficient for the term.
- If V10 is blank, the coupling coefficient is calculated from W1.
- If V10 and W1 are both blank, the coupling coefficient is 0.0.
- For TSAI3D:
- V11: the coupling coefficient for the term.
- V12: the coupling coefficient for the term.
- If V10, V11, and V12 are all blank, the coupling coefficients are calculated from W1, W2, and W3.
- If V10, V11, and V12 and W1, W2, and W3 are all blank, the coupling coefficients are 0.0.
- For TSAI:
- W1,
W2, W3, and W4
definition is dependent on the failure criterion specified.
- PUCK/PUCK3D specify failure envelope
parameters:
- W1
- Failure envelope factor 12(-)
- W2
- Failure envelope factor 12(+)
- W3
- Failure envelope factor 22(-)
- W4
- Failure envelope factor 22(+).
- TSAI3D on anisotropic solid material
If V10, V11 and V12 are blank, they are the tensile stress limits in equal-biaxial tension tests. W1 is the tensile stress limit in equal-biaxial tests where the two tensile loads are in directions 1 and 2. W1 is mandatory, while W2 and W3 are optional. If W2 and W3 are not specified, then they are set equal to W1. The definition of W2 and W3 is similar to W1. W2 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 2 and 3. W3 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 1 and 3.
If V10, V11 and V12 are defined, W1, W2 and W3 are ignored for TSAI3D.
- HASH3D
When Hashin failure criteria is applied on continuum shell elements, W1 is defined as alpha, which takes the transverse shear stress (in 1-2 and 1-3 direction) into account in the tensile fiber check. When W1 is blank, alpha is assumed to be 1.0.
- CNTZ3DWhen using Cuntze failure criterion, W1, W2, and W3, corresponding to the three free curve parameters, , and should be provided. The free curve parameters can be determined from multi-axial test data from experiments. Bounds on the safe side for GFRP, CFRP and AFRP are assumed by Cuntze 1 to be:
(1)
parameters:
- When some failure criteria are defined on
both PCOMP(G/P) (allowables on MATi) and
MATF, then:
- If the same criterion type is defined in both PCOMP(G/P) property and the MATF entry, then the allowables defined on the MATF entry will be used in the failure criterion calculations. The MATF entry overwrites the allowables defined by the corresponding MATi entry (if any).
- If some criteria are only defined on PCOMP(G/P) but not on MATF, then for such criteria, the allowables are taken from corresponding MATi entries.
- If some criteria are defined on MATF, and PARAM,ALLFT,YES exists, then the criteria defined on MATF will use the allowables defined on MATF. However, the criteria not defined on MATF will be calculated based on allowables defined on the corresponding MATi entry.
- The following criteria can only be
PUCK, DUCTILE, PUCK3D, HILL3D, HOFF3D, TSAI3D, HASH3D, STRN3D, and CNTZ3D.
The rest of the criteria can also be defined on the FT field of the corresponding PCOMPP/PCOMPG/PCOMP entry.
For the PUCK failure criterion, even though it is available on the FT field of the PCOMPP/PCOMPG/PCOMP entry, the corresponding failure envelope factors (W1, W2, W3) can only be defined on the MATF entry. Therefore, the MATF entry is mandatory when PUCK failure criterion is requested via the FT field of PCOMP/PCOMPG/PCOMPP entries, and additionally, the allowables should be defined on the MATF for PUCK criterion only. To use PUCK failure criteria, the MATF entry should be specified with MID referring to the corresponding material entry.
- If the CRITERIA field
is set to DUCTILE, then the TID field should
point to a TABLEMD entry with NDEP set to
1. The first data column (Yi) is the
equivalent plastic strain at the onset of damage. The second data column
(Xi) is the corresponding temperature. The second column
should be specified in ascending order only.
When the CRITERIA field is set to DUCTILE in OSTTS analysis, the temperature-based lookup is conducted for each temperature to identify the corresponding equivalent plastic strain from the TABLEMD entry. This plastic strain is used in conjunction with the calculated von Mises Strain to calculate Damage (This can be output using the DAMAGE I/O Options Entry).
- The following tables summarize the
supported failure criteria with different properties and materials.
Table 1. Shell Elements PSHELL PCOMP/PCOMPG/PCOMPP MAT1/MAT2/MAT8 HILL No Yes HOFF No Yes TSAI No Yes STRN No Yes STRS No Yes HASHIN No Yes PUCK No Yes DUCTILE No Yes Table 2. Solid Elements PSOLID PCOMPLS MAT9 MAT9OR MAT9 MAT9OR HILL3D Yes Yes Yes Yes HOFF3D Yes Yes Yes Yes TSAI3D Yes Yes Yes Yes STRN3D Yes Yes Yes Yes STRS3D Yes Yes Yes Yes HASH3D No Yes Yes Yes PUCH3D No Yes Yes Yes CNTZ3D No Yes Yes Yes - Multiple different failure criteria can be defined on a single MATF entry. Therefore, the CRI continuation line can be repeated, and multiple different failure criteria can be specified. However, a particular failure criterion can only appear once on the MATF entry and cannot be repeated. Different failure criteria for different materials can be defined by referencing the corresponding material entry (with same ID as MATF) on MID# fields of the PCOMP(G) and PLY entries (for PCOMPP). If different failure criteria are required to be defined for a single composite property, then MATF entry should be used.
