Loading [MathJax]/jax/output/CommonHTML/jax.js
PSHEAR
Bulk Data Entry Defines the properties of a shear panel.
PSHEAR PID MID T NSM F1 F2
PSHEAR 21 2 .001
PID Unique shear property identification number.
(Integer > 0)
MID Material identification number of a MAT1 entry.
(Integer > 0)
T Thickness of shear panel.
(Real ≠ 0.0)
NSM Nonstructural mass per unit area.
(Real)
F1 Effectiveness factor for extensional stiffness along edges 1-2 and 3-4.
Default = 0.0 (Real ≥ 0.0)
F2 Effectiveness factor for extensional stiffness along edges 2-3 and 1-4.
  1. The effective extensional area is defined by means of equivalent rods on the perimeter of the element. If F1 ≤ 1.01, the areas of the rods on edges 1-2 and 3-4 are set equal to:(1)
    (F1×T×PA)(L12+L34)
    where PA is the panel surface area (half the vector cross product area of the diagonals) and L12 and L34 are the lengths of sides 1-2 and 3-4. Thus, if F1 = 1.0, the panel is fully effective for extension in the 1-2 direction. If F1 > 1.01, the areas of the rods on edges 1-2 and 3-4 are each set equal to (0.5 x F1 x T).
    Figure 1. Extensional Area for Shear Panel
    Thus, if F1 = 30, the effective width of skin contributed by the panel to the flanges on edges 1-2 and 3-4 is equal to 15T. The significance of F2 for edges 2-3 and 1-4 is similar.
  2. Poisson's ratio coupling for extensional effects is ignored.
  3. This card is represented as a property in HyperMesh.
