SECONCT
Bulk Data Entry Defines grid and scalar point connection procedures for a partitioned superelement.
| SECONCT | SEIDA | SEIDB | TOL | LOC | |||||
| GIDA1 | GIDB1 | GIDA2 | GIDB2 | GIDA3 | GIDB3 | etc. |
| SECONCT | 1001 | 1002 | 1.0E-3 | YES | |||||
| 21 | 31 | 22 | 32 | 23 | 33 |
Definition
| SEIDA | Identification number of the superelement to be connected to
SEIDB. No default (Integer 0) |
| SEIDB | Identification number of the superelement to be connected to
SEIDA. No default (Integer 0) |
| TOL | Search tolerance for the boundary grid points. Default = 1.0E-5 (Real) |
| LOC | Coincident location checking for manual connection.
(Character) |
| GIDAi | Identification number of a GRID or SPOINT in superelement
SEIDA, which will be connected to
GIDBi. No default (Integer > 0) |
| GIDBi | Identification number of a GRID or SPOINT in superelement
SEIDB, which will be connected to
GIDAi. No default (Integer > 0) |
- SECONCT can only be specified in the main Bulk Data section and not within a BEGIN SUPER section.
- TOL and LOC can be used to override the default values specified on the SEBULK entries.
- The (GIDAi, GIDBi) pair must both be grids or scalar points.
- This entry will only work if partioned superelements (BEGIN SUPER) exist.
