MCOHED
Bulk Data Entry Defines the material properties for damage-based cohesive material models.
| MCOHED | MID | KI | KII | KIII | SFC | VED | MXDMG | ||
| DMGINIID | DMGEVOID |
| MCOHED | 2 | 9000. | 3000. | 3000. | -1.0 | 1.0e-3 | 0.99 | ||
| 20 | 23 |
| MID | Material
| KX, KY, KZ | Elasticity modulus
corresponding to Mode I, II and III deformation, when the card
is used in cohesive elements. Penalty stiffness corresponding to Mode I, II and III deformation, when the card is used in cohesive contacts. 2 No default (Real) |
for cohesive elements for cohesive contacts |
| SFC | Stiffening factor in compression.
Default = 1.0 |
| VED | Factor for viscous
energy dissipation. 3 Default = 0.0 (Real > 0.0) |
| MXDMG | Maximum damage index,
above which the cohesive element is excluded from
analysis. Default = 1.0 (Real ≥ 0.0) |
| DMGINIID | Damage initiation card
ID. No default (Integer > 0) |
| DMGEVOID | Damage evolution card
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED entries.
- In cohesive contacts, it is recommended to use KII = KIII.
- In some cases, snap-back phenomena could appear in numerical models with cohesive elements. VED can be used to stabilize the solution.
- For additional information, refer to Cohesive Zone Modeling in the User Guide.
