VISCO
Bulk Data Entry Defines parameters for nonlinear analysis involving time-dependent material behavior.
VISCO ID CETOL
VISCO 2
ID Each VISCO Bulk Data card must have a unique ID.
No default (Integer > 0)
CETOL Tolerance for viscoelastic time integration. Ensures that the viscoelastic/creep strain increment is controlled by the specified tolerance.
If not specified or zero, fixed time integration will be used.
No default (Real ≥ 0)
  1. The VISCO Bulk Data entry can be referenced in the subcase section to specify if viscoelasticity/creep analysis will be activated in that subcase.
