Bulk Data Entry Defines a dynamic loading condition for frequency
response problems as a linear combination of load sets defined via RLOAD1
and RLOAD2 entries, or for transient problems as a linear combination of
load sets defined via TLOAD1 and TLOAD2 entries, or
acoustic source ACSRCE entries.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| DLOAD |
SID |
S |
S1 |
L1 |
S2 |
L2 |
S3 |
L3 |
S4 |
L4 |
etc |
etc |
etc |
etc |
etc |
etc |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| DLOAD |
5 |
1.0 |
2.0 |
101 |
2.0 |
102 |
2.0 |
103 |
-2.0 |
201 |
| Field |
Contents |
SI Unit Example |
| SID |
Load set identification
number. No default (Integer > 0)
| S |
Scale factor. No default
(Real)
| S# |
Scale factors. No
default (Real)
| L# |
numbers of RLOAD1 and RLOAD2 or TLOAD1 and TLOAD2, or ACSRCE Bulk Data Entries. No
- Dynamic load sets must be selected in the
I/O Options or Subcase Information sections with
DLOAD=SID. (See I/O Options and Subcase
Information DLOAD entry).
- The load vector being defined by this entry
is given by:(1)
- Each L# must be unique
from any other L# on the same entry.
- SID must be unique from
all RLOAD1 and RLOAD2 or
TLOAD1 and TLOAD2 entries.
- A DLOAD entry may not
reference a set identification number defined by another DLOAD
entry.
- RLOAD1 and
RLOAD2 loads and TLOAD1 and
TLOAD2 loads may be combined only through the use of the
DLOAD entry.
- This card is represented as a load collector
in HyperMesh.
