CMSMETH
Bulk Data Entry Defines the CMS (Component Mode Synthesis) method, frequency upper limit, number of modes, and starting SPOINT ID to be used in a CMS solution.
The eigenvalue solver is also specified. In addition, preload as well as loads for reduction and residual vector generation can be defined. Also, an ASCII file containing CELAS4 and CDAMP3 element data and/or their corresponding design variable definitions can be generated for DMIG to allow the use of the component modes in optimization runs.
| CMSMETH | CMSID | METHOD | UB_FREQ | NMODES | SPID | SOLVER | AMPFFACT | SHFSCL |
| + | UB_FREQ_F | NMODES_F | SPID_F | GPRC |
| + | PRELOAD | SPCID | PLSID |
| + | LOADSET | USETYPE | LSID1 | LSID2 | LSID3 |
| + | DMIGDV | S | OUTOPT | NMODE | DVKUPFAC | DVGEUP | DVBUP |
| CMSMETH | 5 | CBN | 1000 | 200 | 100000 | ||||
| + | 600 | 100 | 200000 |
| CMSID | CMSMETH
identification number. (Integer > 0) |
| METHOD | Component Mode Synthesis
method to be employed. 2
No default (Character) |
| UB_FREQ | Upper bound frequency for
the eigenvalue analysis for the structural part.
Default = blank (Real > 0.0, or blank) |
| NMODES | Number of modes to be
extracted from structural eigenvalue analysis.
Default = blank (Integer > -1, or blank) |
| SPID | The starting
DMIG matrix output for the structural
eigenmodes. No default 6 |
| SOLVER | The eigenvalue solver.
(Character) |
| AMPFFACT | AMSES Amplification
Factor. The substructure modes are solved up to the frequency of
AMPFFACT*V2. Higher values of
AMPFFACT will lead to more accurate results
and longer running times. 9 Default = 5.0 (Real or blank) |
| SHFSCL | For vibration analysis, it
is the estimate of the frequency of the first flexible mode. 12 Default = blank (Real or blank) |
| UB_FREQ_F | Upper bound frequency for
the eigenvalue analysis for the fluid part. If 0.0
or blank, no upper bound is used. 3
4 Default = blank (Real > 0.0, or blank) |
| NMODES_F | Number of modes to be
extracted from fluid eigenvalue analysis. If set to
-1 or blank, number of modes is limitless.
3
4 Default = blank (Integer > -1, or blank) |
| SPID_F | The starting
DMIG matrix output for the fluid
| GPRC | Grid participation
recovery control. Allows fluid-structure interface grid shape data (that is the modes associated with the fluid-structure interface) to be calculated and stored with the external superelement. Only applicable when GM (general modal formulation) is input in the METHOD field and when all boundary degrees-of-freedom are free (BNDFREE). If any boundary degrees-of-freedom are fixed and GPRC is set to YES, the program will be terminated with an error. Default = NO (YES or NO) |
| PRELOAD | Flag indicating that a preload will be used in the CMS analysis. 21 | |
| SPCID | SPC SET ID for the preload. | |
| PLSID | LOAD SET ID for defining the preload. | |
| LOADSET | Flag indicating that static loads will be reduced in CMS superelement generation run. 11 19 | |
| USETYPE | Static loads reduction
type. 11
19
| LSIDi | The static load IDs for generating residual vectors and/or reduced loads. | |
| S | Selects the structural
part of the model. 25 Default = S |
| DMIGDV | Flag indicating that an ASCII file containing CELAS4 and CDAMP3 element data and/or their corresponding design variable definitions is generated for DMIG. 13 | |
| OUTOPT | Defines how design
variable definitions are written for DMIG. 13
17
| NMODE | Defines the number of
design variables for ΔK/ΔGE and ΔB in CELAS4 and
CDAMP3. 18
| DVKUPFAC | Used to determine the
upper bound of ΔK (which is (maximum
eigenvalue)*DVKUPFAC). If
DVKUPFAC is not specified
(DVKUPFAC field is blank). 16 Default: DVKUPFAC=0.1 |
| DVGEUP | Upper bound of ΔGE. This
applies to all the design variables for ΔGE. If
DVGEUP is not specified
(DVGEUP field is blank), by default it is set
to 2*DVBUP. 16 Default: DVGEUP=2*DVBUP |
| DVBUP | Upper bound of ΔB. This
applies to all the design variables for ΔB. If
DVBUP is not specified
(DVBUP field is blank). 16 Default: DVBUP=0.4 |
- This definition will be ignored unless referenced in the I/O Options section by a CMSMETH run control.
- Several methods are available for
Component Mode Synthesis, these are: CB, CC,
CBN, GM and GUYAN (see
descriptions below).
Depending on the type of input required by the Multibody Dynamics Solvers, different methods can be used to generate the flexible body representations. For example, the CB and CC methods are used for generating flexible bodies for use with some Multibody dynamics solvers, like MotionSolve. The CBN method can be used to generate CMS superelement information for some third-party solvers (see Create Output for Third Party Software for more information). Additionally, some of these methods (CBN, GM, GUYAN) can be used to generate external superelements (stored in DMIG format) for use in subsequent finite element analyses.
GUYAN is the same as CBN without including structural eigenmodes; when GUYAN is used, UB_FREQ and NMODES are ignored.
- UB_FREQ, NMODES, UB_FREQ_F and NMODES_F cannot all be blank. Additionally, when structural elements are present in the model, UB_FREQ and NMODES cannot both be blank, and when fluid elements are present in the model, UB_FREQ_F and NMODES_F cannot both be blank.
- When UB_FREQ = 0.0 and NMODES = 0, this is a special case where no structural eigenmodes will be included in CMS mode generation. If both UB_FREQ and NMODES are specified, lowest NMODES below UB_FREQ will be accepted as structural SPOINTs. Similarly things are applied to fluid part.
- If PARAM, EXTOUT, DMIGPCH (or DMGBIN) is defined when using the CB method, a DMIG matrix corresponding to the reduced stiffness and mass matrices will be output. The stiffness and mass corresponding to the eigenmodes will be assigned to the generated SPOINTs.
- The SPOINT IDs of the structure and fluid should have distinct IDs. Any fluid SPOINT ID cannot be in between structural SPOINT IDs.
- When PARAM,EXTOUT is used to output DMIG matrices, then it is possible to disable the output of a flexh3d file by specifying "OUTPUT,H3D,NONE" in the input file.
- The nodal flexh3d file output from the CBN method can be used as the DMIG input (using ASSIGN,H3DDMIG). In this way, the model set output in flexh3d file will be recovered as the interior points of the DMIG matrix in the residual structure run. The displacements of these interior points will be included in the output.
- AMPFFACT is used to increase the accuracy of the eigenvalue and eigenvectors at the expense of slightly longer run times. It is recommended to use higher values of AMPFFACT for solid structures like engine blocks and suspension components. If AMPFFACT is not specified by you and the model contains a large number of solid elements, the value of AMPFFACT is automatically reset to 10.
- The mass properties of the super element (Mass, Center of Gravity, and Moments of Inertia) are written to the H3D file. In the residual run, these mass properties are included in the mass properties of the structure printed in the .out file.
- Static load reduction is supported for CMSMETH superelement generation runs (METHOD=CBN/GUYAN) and Flexbody generation runs (METHOD=CB/CC). Static load reduction is not supported for GM superelement generation runs.
- A specification of SHFSCL may improve the performance of a vibration analysis.
- If the DMIGDV optional continuation card is defined, a text file (ASCII) filename_dmig_dv.inc is created after the run. This file can be included in the original input deck to study how changes in the eigenvalues/damping of superelements affect the performance of the residual structure.
- In addition to the data included in option 1, the ASCII file now also contains design variable definitions. These design variables can control available eigenvalues, structural damping, and viscous damping of the superelement. You can set up an optimization problem by including this file in the original input deck.
- In addition to the data included in option 2, the ASCII file now includes data required for the creation of constraints. These constraints ensure that the eigenvalue of the nth mode is less than the eigenvalue of the (n+1)th mode during optimization.
- The lower bound of ΔK, ΔB and ΔGE is set such that K, B and GE are always greater than or equal to zero.
- The DMIGDV continuation line works only for METHOD = GM (General Modal formulation) in field 3 of CMSMETH. 2
- Where, ΔK, ΔGE and ΔB represent increments/decrements to the eigenvalues (K), damping coefficients (GE) and scalar damping values (B), respectively. It is required to include the .h3d file containing the values of K, GE and B using ASSIGN, H3DDMIG.
- The LOADSET flag is required only for the first continuation line. Multiple continuation lines with LSID's do not require the LOADSET flag.
- For further information on creating flex bodies for third party software, refer to Create Output for Third Party Software in the User Guide.
- Preloading for Component Mode Synthesis subcases can now be defined using the STATSUB(PRELOAD)=SID command. This is more versatile than the PRELOAD continuation line, as any static subcase can be applied as a preload.
- SDAMPING cannot be included in the generation of CMS superelements. SDAMPING can be included in the generation of CDS superelements (CDSMETH entry). If you used SDAMPING in the generation of the combined CDS and CMS (METHOD=GM) superelements, the SDAMPING will be included only in the CDS superelement. Use DMIGMOD to apply SDAMPING in the residual run to the CMS (METHOD=GM) superelements. If SDAMPING is not required for CMS superelements in the residual run, then the corresponding DMIGMOD data can be excluded from the model.
- CMS runs are not supported, if Frequency-dependent materials are present in the model.
- PUNCH output files generated from CMS runs contain ASET, BSET, and CSET information and their corresponding grid and coordinate systems along with the SPOINTs corresponding to the structural eigenmodes.
- Currently, the fluid part of the model cannot be selected for the DMIGDV continuation line on the S field.
- This card is represented as a load collector in HyperMesh.
