SDAMPING
Subcase Information Entry The SDAMPING command can be used to apply modal damping as a function of natural frequency in modal solutions.
SDAMPING(type) = option
Argument | Options | Description |
type | <STRUCTURE, FLUID> | The referenced Bulk Data
Entry is applied to:
option | <SID> No default |
- SDAMPING can only be used in Modal Transient, Modal Frequency Response Analysis, and Modal Complex Eigenvalue Analysis; and must reference a TABDMP1 or TABDMP2 Bulk Data Entry.
- Only one SDAMPING entry of each type can be defined for each subcase.
- If only one type of SDAMPING entry is defined (either SDAMPING(STRUCTURE) or SDAMPING(FLUID)), this definition will be used for both the structure and the fluid portion of the model.
- If present above the first subcase, it is applied to each modal frequency or modal transient subcase without an SDAMPING entry.
- To achieve identical displacements in
Modal frequency response or Modal transient analyses when the
SDAMPING is used instead of PARAM, G,
the steps described here can be followed:
- The TYPE field in the TABDMP1 or TABDMP2 Bulk Data Entry should be set to CRIT.
- Set the damping value (field ) in the TABDMP1 or TABDMP2 Bulk Data Entry equal to half of the value of PARAM,G (that is set the constant value to ).
- Set PARAM, KDAMP,-1
