XSTEP
Subcase Information Entry The XSTEP command can be used to activate the explicit solution method for this subcase and to select the parameters used for explicit analysis.
XSTEP = option
| Argument | Options | Description |
| option | <SID> No default |
- XSTEP Bulk Data Entries will not be used unless selected in the Subcase Information section.
- The XSTEP command is supported in explicit analysis and optimization subcases.
