PARAM, ASCOUP
Bulk Data Entry Generates the fluid-structure coupling (area) matrix for use in the solution.
| Parameter | Values | Description |
| ASCOUP | <YES, NO> |
- PARAM,AGGPCH,YES should be used to output the matrix to the Punch (.pch) file.
- PARAM,ASCOUP,NO is required when the fluid-structure coupling (area) matrix is read in from the Punch (.pch) file.
