PARAM, HOURGLS
Bulk Data Entry Controls the hourglass type.
Parameter Values Description
HGTYP <1, 2, 4> Hourglass control type.
1
Flanagan-Belytschko viscous form (available both solids and shells).
2 (Default)
If HGTYP=2 is defined for solids: Puso enhanced assumed strain stiffness form (available only for eight nodes CHEXA elements.
If HGTYP=2 is defined for shells: Flanagan-Belytschko stiffness form (available for shells only).
4
Reese enhanced assumed strain stiffness form (available only for eight-noded CHEXA elements).
HGFAC
HGTYP=1
<0.05, 0.15>
Default = 0.1
HGTYP=2
<0.0, 0.1>
Default = 0.05
HGTYP=4
<0.0, 0.1>
Default = 0.01
Scale factor for hourglass control forces.
  1. HOURGLS entry referenced on HGID field of PSOLID, PLSOLID, or PSHELL will overwrite the values defined via PARAM,HOURGLS.
