The radiation heat
flux is:(1)
Where,
is the Stefan-Boltzmann constant
(PARAM,SIGMA).
The
temperatures and SIGMA should be defined
in consistent units. Based on the input temperature units,
the absolute temperature scale factor,
, can be defined via
PARAM,TABS. The value of
SIGMA in SI units is 5.67E-8
Watts/m2K4.
