PARAM, NLMON
Bulk Data Entry This parameter activates Nonlinear Results Monitoring. Currently, only displacement results monitoring is available.
| Parameter | Values | Description |
| NLMON | <DISP,
NO> Defaults:
- The generated _nl.h3d file and diagnostic
information in the _nl.out file can be further analyzed
using the script
os_out_file_parser.tcl. For further information on using this script, refer to the NLMON Bulk Data Entry. - PARAM,NLMON is overridden by NLMON Bulk and Subcase Entry pairs for any specified subcase. Supported subcases that do not contain the NLMON Subcase Entry will be influenced by PARAM,NLMON.
- NLMON is currently supported for Small and Large Displacement Nonlinear Static and Large Displacement Nonlinear Transient analysis only. By extension to Nonlinear Transient Analysis, it is also supported for Structural Fluid-Structure Interaction (FSI).
