PARAM, SEPLOT
Bulk Data Entry Outputs display model to .seplot file, from a CMS run.
| Parameter | Values | Description |
| SEPLOT | <YES,
NO> Defaults: The value of this parameter is YES, if it is included in the input file, but no value is provided. The value of this parameter is NO, if it is not included in input file. |
PARAM,
SEPLOT can be used during CMS analysis (only
with the CBN method) to create a .seplot file
that contains the ASET grid data, as well as the
GRID and PLOTEL data
defined using the MODEL I/O
Option. The data is written to the .seplot file
in OptiStruct.
- If there are character entries present in the 10th field of the GRID entry, they will also be printed to the .seplot file (only for the GRIDs involved in the CMS analysis).
