Monarch Complete v15 Features
The list below highlights new features in the Monarch version indicated.
Monarch 15.3
Monarch Classic Highlights:
Data Prep Studio Highlights:
New connectors for Apache Spark SQL, MS Active Directory, Cloudera CDH Drive
Various UI/UX improvements
Various bug fixes
Monarch 15.2
Various bug fixes
Save to Monarch Swarm UI improvements
New connectors for Amazon EMR Hive, Google Drive, Google Sheets, and SugarCRM
Support for connections to Teradata via ODBC
Ability to create new library files from the Application Default Settings dialog
Create new workspaces using the Application menu
Implementation of SWID tagging
Additional aggregations for creating Measure fields when building summaries
Various bug fixes
Monarch 15.1
Various bug fixes
Implementation of Summary functionality to enable better data analysis
Addition of data source connectors for Google BigQuery, Cassandra, and Hubspot
Various bug fixes
Monarch 15.0
Addition of the Base64Encode and Base64Decode functions as conversion functions
Implementation of conversion of Classic models to JSON and export to Swarm
Addition of the Datawatch 7.1.5 Sybase Wire Protocol ODBC driver to enable work with SAP relational database servers
Ability to go to specific columns in the Table and Summary views
Limitation of table copy and export operations to 10 rows for trial versions of Monarch Classic and Complete
Various bug fixes
Implementation of report trapping functionality to enable the systematic extraction of data from PDF and PRN reports
Addition of lookup calculated field support
Implementation of object descriptions at the workspace, table, and change history levels
Various improvements to the Export window and functionality
Implementation of new data connectors (e.g., Google Adwords, Netsuite, Sharepoint, Vertica)
Implementation of runtime parameters
Exports of tables to Angoss and JSON
Improvements to the Append functionality
Implementation of column merging
Implementation of column filters in the Prepare window
Various UX improvements
Various bug fixes
NOTES:
If you have a license for Monarch Complete, you will have access to both Classic and Data Prep Studio features.
If you have a license for Monarch Classic, you will have access to Classic features only.
If you have a license for Monarch Complete with Table Extractor, you will have access to the Classic, Data Prep Studio, and Table Extractor features.
Contact Altair Sales if you would like to upgrade your license to gain access to all of the features listed above and more.
Related Topics
