Edit Change that Created This Column
Allows you to edit changes resulting in a new column. This data prep operation only displays as an option in columns obtained from operations such as create calculated field, create lookup, split, create columns, extract, and merge columns.
In your workspace, right-click on a column created from a previous operation.
Select Edit Change that Created This Column from the options that display.
The corresponding dialog that was used to create the column displays. Use this dialog to modify the selected column.
