/TH/SURF
Block Format Keyword Describes the time history output variables for surfaces.
/TH/SURF/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
obj_ID1 obj_ID2 obj_ID3 obj_ID4 obj_ID5 obj_ID6 obj_ID7 obj_ID8 obj_ID9 obj_ID10
thgroup_ID Time history group identifier
(Integer, maximum 10 digits)
thgroup_name Time history group name
var_ID1, ..n Variables saved for TH (see table below)
(Character, maximum 8 characters)
obj_ID1, ..n Identifiers of the surfaces to be saved
(Integers)
TH Output Keyword & Variables
Keyword Object Saved Variables
SURF Surfaces AREA, MASSFLOW, VELOCITY
Table of Available Variables - Part 2
Keyword Variable Group Saved TH Variables
SURF DEF AREA
Output Variable for Surfaces
  • AREA: Area of the surface
  • MASSFLOW: Accumulated mass flowing through the surface
  • VELOCITY: Flow velocity across the surface
  1. Variable names must be left justified.
  2. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
  3. Surfaces must be defined by shell elements.
  4. MASSFLOW and VELOCITY are only available for internal surfaces of /MONVOL/FVMBAG1 and communication surfaces of /MONVOL/COMMU1.
