/TH/CLUSTER
Block Format Keyword Describes the time history output of spotweld clusters.
/TH/CLUSTER/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
Obj_ID1 Obj_ID2 Obj_ID3 Obj_ID4 Obj_ID5 Obj_ID6 Obj_ID7 Obj_ID8 Obj_ID9 Obj_ID10
Descriptions
thgroup_ID TH group identifier
(Integer, maximum 10 digits)
thgroup_name TH group name
var_ID1, ...n Variables saved for TH (see table below)
(Character, maximum 8 characters)
Obj_ID1, ...n Identifiers of the objects to be saved
(Integer)
TH Output Keyword & Variables
Keyword Object Saved Variables
CLUSTER Spotweld Cluster FX, FY, FZ, MX, MY, MZ, FAIL, FN, FT, MB, MT
Table of Available Variables - Part 2
Keyword Variable Group Saved TH Variables
CLUSTER DEF
FLOC
FN, FT, MB, MT
  1. Spotweld cluster is defined with the /CLUSTER card.
  2. Use parameter Ifail=1 in /CLUSTER for output of FAIL variable.
  3. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
