/TH/CYL_JO
Block Format Keyword Describes the time history for cylindrical joints.
/TH/CYL_JO/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
Obj_ID1 Obj_ID2 Obj_ID3 Obj_ID4 Obj_ID5 Obj_ID6 Obj_ID7 Obj_ID8 Obj_ID9 Obj_ID10
thgroup_ID TH group identifier
(Integer, maximum 10 digits)
thgroup_name TH group name
var_ID1, ...n Variables saved for TH (see table below)
(Character, maximum 8 characters)
Obj_ID1, ...n Identifiers of the objects to be saved
(Integer)
TH Output Keyword & Variables
Keyword Object Saved Variables
CYL_JO Cylindrical joints FX, FY, FZ, MX, MY, MZ
Table of Available Variables - Part 2
Keyword Variable Group Saved TH Variables
CYL_JO DEF
F
M
FX, FY, FZ
MX, MY, MZ
Output for Joint
  • FX: force in direction X
  • FY: force in direction Y
  • FZ: force in direction Z
  • MX: moment in direction X
  • MY: moment in direction Y
  • MZ: moment in direction Z
  • F: magnitude of force
  • M: magnitude of moment
  1. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
