/TH/SPHCEL
Block Format Keyword Describes the SPH cell output to time history.
/TH/SPHCEL/th_group_ID
th_group_title
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
Particle per line, any number of particles may be input
sphcel_ID   sphcel_name
th_group_ID Time history group identifier
(Integer, maximum 10 digits)
th_group_title Time history group title
var_ID1, ..n Variables saved for TH (see table below)
(Character, maximum 8 characters)
sphcel_ID Particle identifier
(Integer)
sphcel_name Name of the particle to appear in time history
(Integer)
  1. Variable names must be left justified.
  2. Available names are listed in the two tables below.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
  3. If variable name is ALL, all TH-variables are saved for this object.
    Variables
    OFF, SX, SY, SZ, SXY, SYZ, SXZ, IE, DENS, WFVIS, VOL, PLAS, TEMP, PLSR, VPLA and DIAMETER
    Variable Saved TH-variables
    DEF OFF, SX, SY, SZ, SXY, SYZ, SXZ, IE, DENS, PLAS, TEMP
  4. Same variables for the option /TH/BRIC are available; except for variable QVIS, which is not available and variables WFVIS (work of artificial viscous forces) and DIAMETER (diameter of the particle) were added.
  5. The following variables are available for all material laws:
    Variable
    OFF
    Element flag
    Stresses in global system
    IE
    Specific internal energy per initial volume
    DENS
    Density
    VOL
    Particle initial volume
    WFVIS
    Work of artificial viscous forces
    DIAMETER
    Particle diameter (smoothing length)
  6. The following variables are only available for the material laws listed:
    Variable Description Law Numbers
    TEMP Temperature 4, 6, 11, 33, 38
    PLAS Equivalent plastic strain 2, 3, 4, 22, 23, 33, 38
    PLSR Plastic strain rate 4, 33, 38
    VPLA Equivalent volumetric plastic strain 10
