/TH/FXBODY
Block Format Keyword Describes the time history for flexible bodies.
/TH/FXBODY/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
Imin | Imax | fxbody_ID |
thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
thgroup_name | TH
group name (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
Imin | Minimum mode index 2 (Integer) |
Imax | Maximum mode index 2 (Integer) |
fxbody_ID | Identifier of the flexible
body to which the mode belongs (Integer) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
FXBODY | Flexible body | IE, KE, EFW, DE |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
FXBODY | DEF | IE, KE, EFW |
Output for Flexible Body
- IE: Internal energy
- KE: Kinetic energy
- EFW: Work of applied forces
- DE: Damping energy
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- Index of local modes for a flexible
body is given by the order in which the modes are written in the Flexible Body Input File.
All local modes whose index lie in the range (max(1,Imin) and min(Imax, Nmod)), where Nmod is the number of local modes of the flexible body identified by fxbody_ID, will be taken into account.
